ÇÖZÜLDÜ help Hp Envy X360 Convertible
hack0358
30 Mar 2024
20
12
I'm new to Hackintosh/Ryzentosh. I installed macOS Sonoma on my Hp Envy X360 Convertible 15-ds0xxx AMD Ryzen 5 3500U. After the installation is complete and the initial setup screen appears, it freezes within a few seconds. Initial settings cannot be completed. In this case, should I change/modify config.plist or Kext? EFI was borrowed from github. I will attach EFI or config.plist. I would appreciate any advice, thank you very much.
9,471
With NVRam Reset
hack0358
30 Mar 2024
20
12
Hello. Thank you for letting me know. After booting, should I do NVRam Reset and restart, then go to the initial settings screen again? Thank you.
Hello. Thank you for your help each time. The initial settings have been successfully completed and you can now start up. Thank you very much for letting me know. Thank you very much. Please excuse me.
